Compile error
  • Compile error
    Here is some code This runs in Tenscripting but produces a compile error in Homeseer.
    It runs in both if I comment out this line .....TempList = {20, 23, 24, 21, 21, 23}
    Public Sub Main(ByVal Parms As Object)
    Dim HouseTime As Integer = hs.DeviceValue(302) '0= Night, 25=Morning, 50=Day, 75=Evening
    Dim TempList() 'YripTemp, BedroomTarget, DrawingTarget, CinemaTarget, GamesTarget,StudyTarget
    Select Case HouseTime
    Case 25 'morning
    hs.WriteLog("Success", "Morning")
    Case Else
    hs.WriteLog("Success", "Day")
    End Select
    End Sub
      Just ran your script under HS3 with no problems.
      Of course, I'm running HS3 under windows. Looks like you are Linux, correct?
      If so, I'd say this is an incompatibility with Mono?
      tenholde
      tenholde
        Thanks Ed
        Yes I think it is an incompatibility issue. I am running mono 3.28 (or something like that). Select...Case worked in the end but Arrays are still problematical. Using trial and error I used different commands / code to achieve what I needed to. I may try and upgrade to mono 4.
        Ian
          Try this:
          TempList = New Object() {20, 23, 24, 21, 21, 23}
          stefxx
            Originally posted by stefxx View Post
            Try this:
            Thank you.
            I did sort out a workaround, similar to that.
            So overall it is a mono issue (i.e. code that will work in Windows but not Linux) or it could be a Mono version issue as I upgraded to Mono 4 but then all of my working scripts refused to compile at all. So back to 3.28.
