Save to ini file how ?
    I have an ini file like this
    [prio]
    plates=
    what script can i use that it puts my virtual device his string into my ini file ?
    like my vitrualdevice string contains : 22fgpl and i want that a script saves it under:
    Plates.ini
    [prio]
    Plates=22fgpl
    is that possible ?
    regards
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    hs.saveinisetting - http://www.homeseer.com/support/home...inisetting.htm
      After you determine the value, assign it to a script variable ["plates_value" in the example below], then save to the ini file using this:
      hs.SaveINISetting("prio", "plates", plates_value, "Plates.ini")
      You can find more info by searching the HS3 help file for hs.SaveINISetting
      Fred
      HomeSeer Pro 3.0.0.548, HS3Touch, Zwave 3.0.1.252, Envisalink DSC 3.0.0.40, WeatherXML, Z-stick, HS phone, Way2Call
        THanks guys !
