I have a script which is supposed to turn a virtual switch on at the end of the month (which then triggers other actions). The script did not trigger yesterday. I also have an event which should trigger at the end of the month, that did not trigger either. There are the script and event in question:
End of month script and event not triggering
Also in the script you have today's date and then today's date + 1 which you are then comparing with more or less than which I think will always be true.
Sent from my SM-G925F using TapatalkZwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
