Device value don't work
    Hi all ,
    i have a power script to monitor my gas..
    now here is the thing, my script writes to a virtual device string but not to the value... the value keeps 0 and the string is updated... what am i doing wrong..
    here is a part of the script
    PHP Code:
    dim TodayDev As String "3401"
    Dim NewValue As Double
    Used
    Meterdecimal LastRead
    NewValue
    Used
    NewString
    =(FormatNumber(NewValue 13))
    hs.SetDeviceValueByRef(TodayDevNewValue)
    hs.SetDeviceString(TodayDevNewStringTrue
    Output log
    PHP Code:
    Nov-10 09:11:59         NewValue    0.0599999999999454
    Nov
    -10 09:11:59         LastValue    0
    Nov
    -10 09:11:59         Used    0.0599999999999454
    Nov
    -10 09:11:59         Meterdecimal    1326.307
    Nov
    -10 09:11:59         MeterDev    1326.307
    Nov
    -10 09:11:59         Lastread1    1326.247
    It correctly writes the string but no the value ..
    Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
    HS3Pro 4.0.8.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
    Being as though the value is very small you probably need to be setting up a value pair with a decimals setting. Although with HS3 you should be able to do this with a device value alone.
      hs.SetDeviceValueByRef has 3 parameters.
      Try:
      hs.SetDeviceValueByRef(TodayDev, NewValue, True)
      Details here.
      Jon
        Try:
        Details here.
        thanksfor your time it works !!
