Best way to "wait" in script?
    Hi,
    I need to force my script to wait in between sending IP/Serial commands.
    I was using:
    Threading.Thread.Sleep(delaymS)
    But seemed to get very unpredictable results.
    I then switched to hs.WaitSecs(delaySecs) which seems to work well - but only accepts an integer and 1 sec is just too big a delay (I have about 14 ip/serial commands to send).
    Any suggestions on best practice?
    Thanks.
    Try the WaitMS function. It's a bit obscure because it is part of the HSPhone application, but I've found it to work reliably.
    HW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF | RFXCOM | Vantage Pro | Green-Eye | X10: XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3 | EtherRain | Ubiquiti
      Originally posted by skavan View Post
      Hi,
      I was using:
      Thanks.
      The documentation is wrong. You can use hs.waitsecs(0.1) for 100mS
      Jon
        Thanks to the both of you...much appreciated.
        How do the HS people get feedback to correct stuff (like documentation?).
        s.
          Good question. Documentation (accurate or otherwise) does not appear to be a high priority at HST.
            s.
            Thankfully by all those nice users that post their findings here as a correction to the many faults in the official documentation.
              s.
              The official way is via Bugzilla, however they never bother to address issues there either.
              Jon
