How to wait?
    How to wait?
    How can I insert a small pause between these commands? I'm thinking they're running too fast for the devices to update properly, essentially running on top of each other as far as the devices are concerned. The result is that many devices will have the same data.
    Sub Main(Parm As Object)
        hs.SetDeviceString(899, hs.DeviceString(898), True)
        hs.SetDeviceString(898, hs.DeviceString(897), True)
        hs.SetDeviceString(897, hs.DeviceString(896), True)
        hs.SetDeviceString(896, hs.DeviceString(895), True)
        hs.SetDeviceString(895, hs.DeviceString(843), True)
        hs.SetDeviceString(843, hs.DeviceString(842), True)
        hs.SetDeviceString(842, hs.DeviceString(840), True)
        hs.SetDeviceString(840, hs.DeviceString(833), True)
        hs.SetDeviceString(833, hs.DeviceString(841), True)
        hs.SetDeviceString(841, hs.DeviceString(186) & " " & hs.DeviceString(187) & " " & hs.DeviceLastChangeRef(186), True)
    End Sub
    Originally posted by rprade
    Try hs.WaitSecs(). The docs say the resolution is only to the second but you can do something like hs.WaitSecs(0.2)
    Don
      So like
      hs.WaitSecs(0.5)
      and so on? No additional commas or parentheses or any such?
        If you want even shorter waits, there's also an HSPhone function: hsp.WaitMS()
        hsp.WaitMS(400) = hs.WaitSecs(0.4)
        I haven't explored the limits, but presumably it's near 1 msec.
        HW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF | RFXCOM | Vantage Pro | Green-Eye | X10: XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3 | EtherRain | Ubiquiti
          Originally posted by S-F View Post
          So like
          hs.WaitSecs(0.5)
          Yes.
            Beautiful. Thanks guys.
