speak temperature
    speak temperature
    There is a post in the how to section on how to speak when temp changes i can not get it to work in HS3 anyone can help would be greatly appreciated here is what i have entered:
    &hs.speak "the temp is & hs.DeviceValue("Q43")/10
    and this is what the log entry is:
    Running script(2) &hs.speak "the temp is & hs.DeviceValue("Q43")/10, init error: Syntax error
    HS3 uses device reference integers... where DevRef is the Reference Number of the Device you are trying to use.
    hs.DeviceValue(DevRef)/10
    or
    hs.DeviceValueByName(DevName)/10
    Hope this is helpful.
    Don
      I tried this:
      &hs.speak "the temp is & hs.DeviceValue(E1AC33E9-025-Q43)/10
      and got this:
      Error Running script(2) &hs.speak "the temp is & hs.DeviceValue(E1AC33E9-025-Q43)/10, init error: Unterminated string constant
      also tried:
      Error Running script(2) &hs.speak "the temp is & hs.DeviceValueByName(Temperature)/10, init error: Unterminated string constant
      Dec-02 4:29:23 AM Event Running script statement immediately: &hs.speak "the temp is & hs.DeviceValueByName(Temperature)/10
      Dec-02 4:29:23 AM Event Event Trigger "Speak Temperature Speak Temperature"
      Dec-02 4:29:23 AM Z-Wave Device: Node 25 Z-Wave Temperature Set to 61.1 (F)
        I tried this:
        and got this:
        also tried:
        Not sure if that value is a name or not, but if it's the name you need to do it like
        &hs.speak("the temp is " & hs.DeviceValueByName("E1AC33E9-025-Q43")/10)
        Last edited by sirmeili; December 2, 2016, 09:30 AM. Reason: Changed DeviceValue to DeviceValueByName
        MeiAutomtion Home
          You can also use Replacement variables. Look here for more info on them:
          http://homeseer.com/support/homeseer..._variables.htm
          Z
            You need to use the Device Reference ID as shown here. You were using the Technology address, I think. Or you can use the replacement variable as suggested.
            I tried this:
            and got this:
            also tried:
            Don
              Here is a one liner event that speaks time and temperature based on the reference numbers that Don mentioned above. It's not a script rather it is just text with references.
              You tell Homeseer to speak the text; easy peasy.
              Today is $date. The time is $time. The outside temperature is $$DVR:129: degrees. The inside temperature is $$DVR:1087: degrees. The relative humidity is $$DVR:1086: percent.
              Where as DVR is device reference number and you need two dollar signs in front of DVR. In the beginning of HS3 I had issues as always thought about way things were done in Homeseer 2.
              Too you can create a temperature variable and it automatically creates a reference ID for it. I do that reading 1-wire temps from the RPi2 in the attic. It is just a text file read using python, perl or just bash and HS scripting for the variables.
              - Pete
              Auto mator
              Homeseer 3 Pro - 3.0.0.548 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU 16Gb- Mono 6.12.X
              HS4 Pro - V4.1.7.0 - Ubuntu 18.04/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.12.x
              HS4 Lite -
                I want to thank everyone for there help i used both script first then i tried the variable i liked the secound. which leaves me to ask another it speaks every slight change like from 76.1 to 76.2 would like it to just do hole numbers,,
                  Just guessing here...
                  Convert.ToInteger(hs.DeviceValue(DevRef)/10)
                  Don
                    We speak the time and temperature on the hour. That satisfies my needs and is what makes my wife happy. She doesn't like a lot of chatter.
                    It is silent after 10:00PM and before 7:00AM on work days or before 9:00AM on weekends, holidays or days off.
                    Randy Prade
                    Aurora, CO
                    Prades.net
                      For my temperature sensors I like whole numbers so I use this in the beginning of the script.
                      dim FTemp,CTemp,Humid as Short
                      Use the Short data type to contain integer values that do not require the full data width of Integer. In some cases, the common language runtime can pack your Short variables closely together and save memory consumption.
                      The default value of Short is 0
                      I am currently using a 1-wire network which writes to a text file every minute or so. The text file is read by script and converted to HS variables.
                      Here is one line / one 1-wire combo temperature and humidity sensor where the text file shows the temperature in Centigrade and Fahrenheit.
                      Aug 27 22:20:04 Sensor 1 C: 28.28 F: 82.91 H: 50%
                      - Pete
                      Auto mator
                      HS4 Lite -
