Passing multiple parameter to .vb from HStouch
  • Passing multiple parameter to .vb from HStouch
    I have a script, currently real simple:
    Sub Main(ByVal Parms() As Object)
      hs.writelog("Parameter Test",Parms(0))
      hs.writelog("Parameter Test",Parms(1))
    End Sub
    and I want to send 2 parameters from HStouch which are not based on an element. In the Action Editor, I set it to run a script and set the script to be:
    &hs.runScriptFunc("IncrementTime.vb","Main",{"Turn Module On",30,False,False)
    I keep getting init error: Invalid character
    I believe my problem is how I am trying to pass 2 parameters. Any suggestions on where I am going wrong?
    I don't believe you can pass an array from an immediate script command. FYI, there's a typo in your immediate function: ] instead of } to close your array definition, it should read as follows:
    &hs.runScriptFunc("IncrementTime.vb","Main",{"Turn Module On",30,False,False})
    You can instead pass multiple values in a comma (or other character) delimited string:
    &hs.runScriptFunc("IncrementTime.vb","Main","Turn Module On,30,False,False")
    And change your code to:
      Dim sTemp As String() = Split(Parms,",")
      hs.writelog("Parameter Test", sTemp(0))
      hs.writelog("Parameter Test", sTemp(1))
    End Sub
    Best regards,
    -Mark-
      I had to change it to
      &hs.runScriptFunc("IncrementTime.vb","Main","Turn Module On,30",False,False)
      as the False, False are not part of the passed parameters. Otherwise this seems to work. Thank you. I did try a lot of different variations as well with no success.
