CAPI on Linux Sonos toggle Mute
    Does anyone know how to toggle the MUTE on Sonos I assume you need to use CAPI?
    I tried copying and modifying the CAPI for the volume that works but cant seem to make it work.
    Here is the code I tried:
    Sub Main(ByVal str0 As String)
    Dim str as string
    Dim ref as string
    Dim cc As HomeSeerAPI.CAPI.CAPIControl
    Dim cr As HomeSeerAPI.CAPI.CAPIControlResponse
    ref = hs.GetDeviceRefByName("Mark Mute")
    str = hs.DeviceValue(ref)
    hs.WriteLog("Info","The mute is set to: " & str)
    cc = hs.CAPIGetSingleControl(ref, True, "Muted", False, False)
    if str = 1001  then
    hs.WriteLog("Info","is mute")
    cc.ControlValue = 1000
     else
    hs.WriteLog("Info","not mute" )
     cc.ControlValue = 1001
     end if
    cr = hs.CAPIControlHandler(cc)
    hs.WriteLog("Info","mute: " & str)
    End Sub
    My SONOS devices already have a toggle option so you shouldn't need to do anything complex. I've even managed to get it down to a single line.
    hs.CAPIControlHandler(hs.CAPIGetSingleControl(62, True, "Toggle", False, False))
    End Sub
    You need to replace 62 with your SONOS mute device.
      End Sub
      Perfect works great! Thank you
