get last word in string for Sonos Player
    I have a string heard by HS via Alexa. I would like to get the last word from the string so I can change Sonos Play
    For example the script gets this parm passed to it:
    run living room stop
    How do I get the STOP on the end?
    I would normally look for instrrev and find the last space and then use substr to
    get the last word. I didnt find any reference in the PDF for this.
    Thank you
    This should do it for you - you'll need to change it to accept a parameter via than the string I have forced it to accept.
    Sub Main(ByVal Parm As Object)
        Try
            Dim input as String = "run living room stop"
            Dim splInput() as string = input.split(chr(32))
            hs.writelog("", splInput(splInput.GetUpperBound(0)))
        Catch ex As Exception : hs.writelog("", "Exception: " & ex.message)
        End Try
    End Sub
          Try
          End Try
      End Sub
      This works perfectly! Thanks again!
