Was playing around this morning to work out a script that can control my Aeon Labs RGB bulbs (model ZW098). I'd like these bulbs to shift from cooler colors to very warm (basically red) colors based on time of day, similar to what apps like f.lux do for computer screens.
As a disclaimer - these bulbs aren't very good. Compared to the wifi bulbs on the market the colors and brightness are terrible - but it is the only zwave option I am aware of.
Anyway, the hardest part was figuring out how to set the RGB values in a single CAPI call (requires use of a different property). This first draft of the script is designed to just run on an interval (30 minutes) and based on the time of day it will iterate through the list of bulbs defined and set them to one of three colors (two defined colors using the RGB values, and one 'warm white' property that turns on the brighter white led's in the bulb).
I'm working now to make this calculate more of a sine wave and adjusts finer colors throughout the day, slightly shifting every interval to the ideal color -- but this will give you some ideas if you are hoping to control this bulb.
In this rough version you just add device.Add() calls, each with the name of the RGB device and the name of the Warm White device for that bulb. Two bulbs are listed in this example.
using System.Collections.Generic; using HomeSeerAPI.CAPI; const int SunriseWindowHours = 1; public object Main(object[] Parms) { try { hs.WriteLog("Info","Circadian Lighting Script Running"); // Devices List<Tuple<string, string>> devices = new List<Tuple<string, string>>(); devices.Add( new Tuple<string, string>( "Office Custom RGB", "Office Color Control Warm_White Channel") ); devices.Add( new Tuple<string, string>( "Office Fan Custom RGB", "Office Fan Warm_White Channel") ); // Add more devices here... // Get sunrise, sunset and noon DateTime sunrise = hs.SunriseDt; DateTime sunset = hs.SunsetDt; DateTime solarNoon = hs.SolarNoon; DateTime current = DateTime.Now; // Color constants string colorSunriseSunset = "#ff9000"; string colorNight = "#ff5400"; // Configure devices foreach(Tuple<string, string> device in devices) { int deviceReferenceRgb = hs.GetDeviceRefByName(device.Item1); int deviceReferenceWarm = hs.GetDeviceRefByName(device.Item2); // Are we within the sunrise/sunset window? if (current.Subtract(sunrise).Duration().TotalHours < SunriseWindowHours) { SetWarmWhite(deviceReferenceWarm, false); SetRgbColor(deviceReferenceRgb, colorSunriseSunset); } // Is it after sunset window? else if (current >= sunset.Add(TimeSpan.FromHours(SunriseWindowHours)) || current < sunrise.Subtract(TimeSpan.FromHours(SunriseWindowHours))) { SetWarmWhite(deviceReferenceWarm, false); SetRgbColor(deviceReferenceRgb, colorSunriseSunset); } // Default to warm white for rest of the day else { SetWarmWhite(deviceReferenceWarm, true); } } return 0; } catch (Exception ex) { hs.WriteLog("Error",ex.ToString()); return 1; } } public void SetRgbColor(int device, string color) { HomeSeerAPI.CAPI.CAPIControl capiControl; capiControl = hs.CAPIGetSingleControl( device, true, "Custom Color(value)", false, false); capiControl.ControlString = color; hs.CAPIControlHandler(capiControl); } public void SetWarmWhite(int device, bool turnOn) { HomeSeerAPI.CAPI.CAPIControl capiControl; capiControl = hs.CAPIGetSingleControl( device, true, "Warm White Level (value)", false, false); capiControl.ControlValue = turnOn ? 200 : 0; hs.CAPIControlHandler(capiControl); }
