Aspx & Controlling Device
    I am trying to start really simple but even then fail. My starting point is the test.aspx file that is included with HS3. I do see the site and it reports the HomeSeer version and the name of the z-wave plugin. So clearly it was able to establish a connection. What I did next is modify the Button1_Click function by simply executing the following:
    hs.SetDeviceValueByRef(22, 99, True)
    22 it the reference ID of my device. The value 99 represents ON. I also tried SetDeviceValue and SetDeviceValueByName. However, whenever I click on the button nothing happens. Any pointers how to get this to work?
    Edit: Btw, is there a way to debug this? On the client side the button is rendered with type='submit' so I can't really do anything on the client side and I don't know how to intercept calls on the 'server side'.
    Rather than setting the device value which only normally sets a value to that device, you need to use the Homeseer CAPI interface: http://help.homeseer.com/help/HS3/st...ce_control_api
    Try the following to turn your device on:
    hs.CAPIControlHandler(hs.CAPIGetSingleControl(22, True, "On", False, False))
    Jon
      Ah, that was it. With SetDeviceValueByRef I could see the status change on the device management page. However, the device didn't actually change its state. After using the CAPI functions it started to work. Thank you!!!
        From
        to
        hs.CAPIControlHandler(hs.CAPIGetSingleControl(22, True, "On", False, False)) is called progress ???!?.
        Things should get easier, not more complicated.
        Whoever dreamed up this nightmare took programming decades back.
        (Sorry for the ramble)
        jon00 Thanks for sharing this info. It will go in my personal notes to remember this.
        - Bram
        Send from my Commodore VIC-20
        Ashai_Rey____________________________________________________________ ________________
        HS3 Pro 3.0.0.534
        PIugins: ZMC audio | ZMC VR | ZMC IR | ZMC NDS | RFXcom | AZ scripts | Jon00 Scripts | BLBackup | FritzBox | Z-Wave | mcsMQTT | AK Ikea
          Originally posted by AshaiRey View Post
          From
          to
          Hah...you can read all about it here: https://oldforums.homeseer.com/showthread.php?t=167405
          The reason given in that thread is IMO not valid as HST implemented a single command when JSON control came along...
          Jon
            Wow - I had forgotten that thread. I just spent 10mins reliving the past
            67 Z-Wave Nodes, 111 Events, 422 Devices
            Z-Wave, UPB, WiFi
            Plugins: EasyTrigger, weatherXML, OMNI, Z-Wave, Tuya, Device History
              Just relived the thread too.
              4 years further and no one is annoyed enough from all the extra work to do what was a simple syntax before and write a wrapper around the CapiControl.
              - Bram
              HS3 Pro 3.0.0.534
