Noobie Scripting help
    Trying to do a very simple script do do the following.
    1) compare the humidity from the Nest thermostat to the humidity of the bathroom.
    2) Record the Nest Humidity every hour to a virtual device
    I am completely new to scripting. here is what I started with but it does not change the value on the virtual device.
    Sub Main(params as object)
    ' sets value of ambient humidity Device
    hs.SetDeviceValue(421,hs.DeviceValueEx(419))
    End Sub
    3) after this I would like to compare the Master Bath humidity to the NEst value when the master bath value changes. If it is over a threshold value i would run an event.
    No idea how to do this. Want to learn. Any help would be appreciated.
    Jason
    End Sub
    Jason
    Not as fun as writing a script, but the Easy Trigger plugin can do this in an event.
    Plugin's:
      End Sub
      Are you seeing an error in the log? Try changing the function to:"
      hs.SetDeviceValueByRef(421, hs.DeviceValueEx(419), True)
        Thanks Profit! I would like to see if I can get the script to work. Would allow me more freedom to mess things up in the future.
          It worked for a minute then i tinkered and tried to get two devices values from two other devices.
          hs.SetDeviceValueByRef(421, hs.DeviceValueEx(419) True)
          hs.SetDeviceValueByRef(423, hs.DeviceValueEx(369) True)
          End Sub
          Now i get these errors.
          Sep-28 4:51:31 PM Error Compiling script /usr/local/HomeSeer/scripts/AmbientHumidity.vb: 'End Namespace' must be preceded by a matching 'Namespace'.
          Sep-28 4:51:31 PM Error Compiling script /usr/local/HomeSeer/scripts/AmbientHumidity.vb: Identifier expected.
          Sep-28 4:51:31 PM Error Compiling script /usr/local/HomeSeer/scripts/AmbientHumidity.vb: Expected 'End'.
          Sep-28 4:51:31 PM Error Compiling script /usr/local/HomeSeer/scripts/AmbientHumidity.vb: Expected ')'.
          Sep-28 4:51:30 PM Error Compiling script /usr/local/HomeSeer/scripts/AmbientHumidity.vb: 'End Namespace' must be preceded by a matching 'Namespace'.
          Sep-28 4:51:30 PM Error Compiling script /usr/local/HomeSeer/scripts/AmbientHumidity.vb: Identifier expected.
          Sep-28 4:51:30 PM Error Compiling script /usr/local/HomeSeer/scripts/AmbientHumidity.vb: Expected 'End'.
          Sep-28 4:51:30 PM Error Compiling script /usr/local/HomeSeer/scripts/AmbientHumidity.vb: Expected ')'.
          Sep-28 4:51:29 PM Error Compiling script /usr/local/HomeSeer/scripts/AmbientHumidity.vb: 'End Namespace' must be preceded by a matching 'Namespace'.
          Sep-28 4:51:29 PM Error Compiling script /usr/local/HomeSeer/scripts/AmbientHumidity.vb: Identifier expected.
          Sep-28 4:51:29 PM Error Compiling script /usr/local/HomeSeer/scripts/AmbientHumidity.vb: Expected 'End'.
          Sep-28 4:51:29 PM Error Compiling script /usr/local/HomeSeer/scripts/AmbientHumidity.vb: Expected ')'.
            Here is the new script:
            DIM HumidDiff as integer
            DIM HumidAmb as integer
            DIM HumidMB as integer
            'HumidDiff difference of the ambient and Master bath Humidity
            'HumidAmb Ambient Humidity
            'HumidMB Master bath Humidity
            HumidAmb = hs.DeviceValueEx(419)
            HumidMB = hs.DeviceValueEx(369)
            HumidDiff = HumidMB-HumidAmb
            hs.SetDeviceValueByRef(423, hs.DeviceValueEx(369), True)
            hs.SetDeviceValueByRef(424, HumidDiff, True)
            End Sub
            Only error that i get is:
            In device utility postback: Conversion from string "424,424" to type 'Integer' is not valid.
            And when it runs it seems to run 5 times. Device 424 is a virtual device that just shows the humidity difference. Any help is appreciated.
            Jason
              How are the humidity values reported?
              Try changing the declaration of your variables to Double rather than Integer.
              You could also try adding these lines just before the hs.Set commands:
              hs.WriteLog("HumidDiff", CStr(HumidDiff))
              hs.WriteLog("HumidAmb", CStr(HumidAmb))
              hs.WriteLog("HumidMB", CStr(HumidMB))
