I've created a script in tenScripting that executes as expected and doesn't generate any errors and I can see. When I export the script to HS and run it I get the following errors in the log and don't understand why.
Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\LightSchedule.vb: Type 'List' is not defined. |
Dec-11 7:33:45 PM | Error | Compiling script C:\Program Files (x86)\HomeSeer HS3\scripts\LightSchedule.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases. |
