Script to compute Time Differential
  • Script to compute Time Differential
    Hey Experts I am trying to write a script which computes the differential between two Times (days , hours, minutes, seconds). I am at a basic level here... I would simply like to have Homeseer save Time1 to a variable (e.g. when temperature is below freezing) , and Time2 to a different variable (e.g. when temperature rises above freezing) . Then I would like to compute the difference between the two variables (in minutes , hours , days, etc). Thank you in advance for assistance.
    Does this help?
    https://www.tutorialspoint.com/vbscr...cript_date.htm
      Why not just use a timer in events?
      Greig.
      Sent from my SM-G950F using Tapatalk
      Scripts =
      Various
        Since you are doing this in script, VB .Net has built in functions to do exactly what your want. Specifically the DateAdd function. Some specifics:
        https://docs.microsoft.com/en-us/dot...ramework-4.7.2
          Or the DateDiff function: https://docs.microsoft.com/en-us/dot...ramework-4.7.2
