Trying to add a Reference ID Value into a vb script
  • Trying to add a Reference ID Value into a vb script
    Managed to "borrow" a script which will turn a google map into a .png file but I am struggling to insert the device reference values into the google line required
    I have tested the actual long/latitude Map string and it creates a .png map for me to view in HSTouch, but obviously instead of numbers I need to grab the values from the device reference values
    Dim MapStr As String
    Dim ReturnStr As String
    MapStr = "/maps/api/staticmap?center=51.76,-0.23&zoom=17&size=640x400&markers=color:white%7Clabel:A%7C51.76,-0.23&maptype=hybrid&key=GOOGLEAPIKEY"
    ReturnStr = hs.getURLImageEx("http://maps.googleapis.com", MapStr, hs.getapppath & "\map.png", 80)
    If ReturnStr <> "" Then
    hs.writelog("Error", "Error In Downloading Map Image")
    End If
    End Sub
    I need to grab the 51.76 latitudes from my Device Reference ID 792, and my -0.23 longitudes from Device Reference ID 793 but don't know the required script to add these two successfully into the line, anybody know?
    Many thanks in advance...
    Are they stored as device values or in the device strings?
    HS3 Pro Edition 3.0.0.548
      They are stored as Device Values, the string is blank
        Something like:
        Dim Latitude As String = hs.DeviceValueEx(792).ToString
        Dim Longitude As String = hs.DeviceValueEx(793).ToString
        MapStr = "/maps/api/staticmap?center=" & Latitude & "," & Longitude & "&zoom=17&size=640x400&markers=color:white%7Clabel:A%7C" & Latitude & "," & Longitude & "&maptype=hybrid&key=GOOGLEAPIKEY"
        should work.
          Sparkman, that worked a treat. Thank you very much
