I'm trying to cycle thru the list of devices and if any of these conditions are right, then check to see if time is great then .... How do I write this statement?
For Each hs.getDeviceByRef(Nothing) As Integer In ListOfDevices
PHP Code:
Dim ListOfDevices() As Integer = {215, 246, 509}
'215 - Category: Sprinkler - Acual Rain Prior 1 Day
'216 - Category: Sprinkler - Average Wind for 20 Min
Try
Dim dv As Scheduler.Classes.DeviceClass
Dim EN As Scheduler.Classes.clsDeviceEnumeration
EN = hs.GetDeviceEnumerator
If EN Is Nothing Then
hs.WriteLog("BatteryReport", "Error getting Enumerator")
Exit Sub
End If
Do
dv = EN.GetNext
If dv Is Nothing Then Continue Do
' For Each Device As Integer In ListOfDevices
'If InStr(UCase(dv.Device_Type_String(Nothing)), "BATTERY") > 1 Then
If hs.DeviceTime(Device) > 1440 Then
ReDim Preserve myArray(UBound(myArray) + 1)
myArray(UBound(myArray) - 1) = New BatteryDevice
myArray(UBound(myArray) - 1).refID = ("[" & dv.Ref(Nothing).ToString & "]")
myArray(UBound(myArray) - 1).devValue = (dv.devValue(Nothing).ToString & " ").PadLeft(7)
myArray(UBound(myArray) - 1).devName = dv.Location2(Nothing) & " " & dv.Location(Nothing) & " " & dv.Name(Nothing)
myArray(UBound(myArray) - 1).lastChange = dv.Last_Change(Nothing).ToString
' End If
End If
Next
Loop Until EN.Finished
