get information from growatt.com
  • get information from growatt.com
    I have solar panels from growatt and want to input the readings in HS devices.
    But to get the info, I have to login to their website: http://server.growatt.com/
    How can I make a .vb script to login and get my information?
    I know I can get a website in a variable wit hs.GetURL, but I don't know how I can login first.
    Peter
    http://ohh.pcgsm.nl
    Found this code on the web.
    But I don't know if I first must make a connection to the website followed by this code.
    Can I run this with userName and password at once, or do I have to run the code for username and again for password?
    Who has experience getting data from a website that needs a login?
    Imports System.IO
    Imports System.Net
    Imports System.Text
    Sub Main(parm As Object)
        Const debug = True
        Const server = "server.growatt.com"
        Const postData = "userName=naam&password=wachtwoord"
         ' Create a request using a URL that can receive a post.
        Const server_url = "https://" & server & "/login"
        Dim request As WebRequest = WebRequest.Create(server_url)
        ' Set the Method property of the request to POST.
        request.Method = "POST"
        ' Create POST data and convert it to a byte array.
        Dim byteArray As Byte() = Encoding.UTF8.GetBytes(postData)
         ' Set the ContentType property of the WebRequest.
        request.ContentType = "application/x-www-form-urlencoded"
        ' Set the ContentLength property of the WebRequest.
        request.ContentLength = byteArray.Length
        ' Get the request stream.
        Dim dataStream As Stream = request.GetRequestStream()
        ' Write the data to the request stream.
        dataStream.Write(byteArray, 0, byteArray.Length)
        ' Close the Stream object.
        dataStream.Close()
        ' Get the response.
        Dim response As WebResponse = request.GetResponse()
        ' Display the status.
        If debug Then hs.writelog("POST request", CType(response, HttpWebResponse).StatusDescription)
        ' Get the stream containing content returned by the server.
        dataStream = response.GetResponseStream()
        ' Open the stream using a StreamReader for easy access.
        Dim reader As New StreamReader(dataStream)
        ' Read the content.
        Dim responseFromServer As String = reader.ReadToEnd()
        ' Display the content.
        If debug Then hs.writelog("POST response", responseFromServer)
        ' Clean up the streams.
        reader.Close()
        dataStream.Close()
        response.Close()
        ''validateCode
    End Sub
    Peter
    http://ohh.pcgsm.nl
      Have you looked at Jon00's data scraper script?
      HS3 Pro Edition 3.0.0.548
        I have tested his script.
        The problem is that I have to login first and then go to another page for the data.....
        Peter
        http://ohh.pcgsm.nl
