is there a tutorial on how to get started in scripting with HS3 or HS4? Would like to know how to make calls to the script from HS and where to place the files.
How to get started in scripting?
The files are placed in ........../HomeSeer/scripts. The scripts are called from events in HomeSeer as shown in the snippet below:
You are not just limited to VB/C# etc scripts. You can also run command line scripts or different processes. There is documentation on scripting in tools->setup ... Homeseer help file. This will give you basics on scripting (function calls, simple syntax etc). The forum has a lot of information on scripting and many examples. Look in the howto section.
Hope this helps
Ed Tenholder has developed some useful tools to help with vb.net scripting.Mike____________________________________________________________ __________________
I have an HS-WD200+ that turns on/off my outside lights. Sometimes the lights are turned on via a Scheduled Event and sometimes when I manually press the paddle. I would like the LEDs to turn Red when the lights are ON and Green when the lights are OFF. I don't want the LEDs manipulated from the Scheduled Event or from the Manual paddle press; I want the LEDs to follow the "Switch Multilevel" status of ON/OFF. I do not use the dimmer.
Originally posted by Bugman1400 View PostSimple really. I have an HS-WD200+ that turns on/off my outside lights. Sometimes the lights are turned on via a Scheduled Event and sometimes when I manually press the paddle. I would like the LEDs to turn Red when the lights are ON and Green when the lights are OFF. I don't want the LEDs manipulated from the Scheduled Event or from the Manual paddle press; I want the LEDs to follow the "Switch Multilevel" status of ON/OFF. I do not use the dimmer.HS 4.2.8.0: 2134 Devices 1252 Events
Originally posted by Bugman1400 View PostPerhaps you were offended by the wording of my reply. I’ve edited it in an effort to be less distracting from the main point. Any help is sincerely appreciated.HS 4.2.8.0: 2134 Devices 1252 Events
- Likes 1
Originally posted by Bugman1400 View PostI’d rather change the color of the LEDs based on the status of the multilevel device and not the external triggers. This because the external triggers don’t always get noticed.
Originally posted by Bugman1400 View PostI’d rather change the color of the LEDs based on the status of the multilevel device and not the external triggers. This because the external triggers don’t always get noticed. However, a polling of the device would notice the change of the status and change the LED color.HS 4.2.8.0: 2134 Devices 1252 Events
