End of statement Expected
    Can anyone help with this?
    Works fine in Windows but not in Linux.
    Sub MuteTog (ByVal Parms() As String)
        Dim theZone As Double = parms(0)
        Dim curVol As Double = hs.DeviceValueEx(theZone)
        Dim lastVol As String
                if curVol > 0 then
                    hs.CreateVar("volSet")
                    lastVol = hs.SaveVar("volSet",curVol)
                    Dim cc as HomeSeerAPI.CAPI.CAPIControl = hs.CAPIGetSingleControl(theZone, True, "(value)", False, False)
                    cc.ControlValue = 0
                    Dim cr as HomeSeerAPI.CAPI.CAPIControlResponse = hs.CAPIControlHandler(cc)
                Elseif curVol = 0 then
                    lastVol = hs.GetVar("volSet")
                    cc.ControlValue = lastVol
                    hs.DeleteVar("volSet")
                End if
    End Sub
    Getting End of Statement Expected.
    Have you tried coping over the working script file from Windows to Linux? You may have a hidden character on the page in the Linux version
    Jon
      I Have.
      It's the same file.
        If you remark out all the lines except:
         End Sub
        Does that run?
        Jon
          If not try:
           Sub MuteTog (ByVal Parms As Object)
           End Sub
          Jon
            End Sub
            Does that run?
            No. Same error
            If not try:
            Sub MuteTog (ByVal Parms As Object) End Sub
            Same error
              How is the sub being called? Via an event? If so you cannot send a string array via this method.
              Jon
                From a button press in HSTouch.
                Keep in mind, it works in Windows.
                BLRussound plugin doesn't have a mute function ( why not?? ) so I use this script to toggle mute.
                  Can you show me the button code you are using?
                  Jon
                    I have the text on the button invisible but it is the refID of the audio zone volume.
                    The button press sends that refID to the script.
                      I'm at a loss then.
                      End Sub
                      If the above fails, then there must be a bug as an object should accept any parameter type.
                      Jon
                        Thanks for trying!
                          It could of course be a mono issue but that is difficult to diagnose.
                          Jon
                            Originally posted by Demusman View Post
                            Thanks for trying!
                            Just a note: HS Touch passes parameters to scripts as an array of strings, whereas a Homeseer event passes only the parameter as a single string. Makes for a small bother when you want to call a routine from both sides.
                            I use the following code to handle calls from both sides:
                            Public Sub AlarmDefault(parms As Object)
                              Dim buff As String, iValue As Double
                              If parms.GetType().ToString = "System.String" Then
                                buff = parms.ToString()
                              Else ' parms is an Array of string
                                buff = parms(0).ToString()
                              End If
                              iValue = CDbl(buff)
                            End Sub
                            Note that other than the Main subroutine, I declare other subroutines "Public" if I want to call them directly from Touch or an event.
                            Try something like that. If it still fails, it would be interesting to actually see the error message you are getting in the HS log.
                              Got a feeling it's a Mono issue. None of my scripts are working. All of them worked fine in Windows. Haven't really played with it at all today but I'll give your suggestion a try when I can.
                              There error is the title of this post.
