HSDesigner
    HSDesigner
    I posted this in the designer section but it may be better here. How do you run a script in HSTouch? I want to be able to enter text into a box and have it update a device value.
    On the element you want to activate when pressed, Choose on of the actions and select Run a HomeSeer script with values from elements
    Choose your script and save.
    When an element is pressed the script will run. See screenshot
Name:	Screenshot from 2020-04-02 15-34-32.png
      I get that but how do I format the script to use the element?
        Be aware that parameters are passed differently from HS Touch than when called from an Event Action. The Event Action passes a single string, HS Touch passes an array of strings (even if there is only one parameter). The best way to handle this is to declare the parameter in your subroutine declaration as type "Object". Then check within your code as to whether it is a single string or an array of strings.
          I have very little coding skills I have no clue how to format the script to get it to use the parameters from HSTouch.
            So if this is my script how do i put the parameter in from hstouch?
            Main(ByVal Parms As object)
            hs.SetDeviceValueByRef(287, "ScriptParameter1", TRUE)
            End Sub
              Events pass parameters to subroutines as 1 long string. You have to use a character (delimiter) to split the parameters apart. HSTouch sends multiple parameters and these need to be concatenated to be able to handle the same. I use "|" as the delimeter. If you are only passing one parameter then you can delete everything after the red. Parm becomes your parameter in the single parameter case. you can convert the type from string to Integer by using CInt(). If you need other conversions then look here -https://docs.microsoft.com/en-us/dot...sion-functions. I have no idea why HS decided to do it this way as it seems anti-intuitive to use two methods.
              Sub Main(ByVal parms As Object) 'ByVal Means the parameters will be passed on the stack.
              Dim parm, sParm() As String 'All parameters will start life as a String
              If parms.GetType().ToString = "System.String" Then 'Called from an Event
              parm = parms.ToString() 'Parm is set to a concatenated string
              Else ' Called from HSTouch
              parm = parms(0).ToString() & "|" & parms(1).ToString() & "|" & parms(2).ToString() & "|" & parms(3).ToString() ' create concatenated string so can handle both calls the same
              End If 'Now use parm as your input variable...
              sParm = Split(parm, "|", -1, 1) 'Split into array of parameters. This is not necessary if you only passing one parameter.
                You actually have to use the CAPI control API in order to control a device.
                I use the following two "helper" functions in my scripts to make my coding life easier. See below:
                Private Function SetVirtualVal(ByVal sDevName As String, ByVal dVal As Double) As Integer
                ' Sets the value of a device using CAPI Control
                  Dim iRef As Integer = hs.GetDeviceRefByName(sDevName)
                  For Each objCAPIControl As CAPIControl In hs.CAPIGetControl(iRef)
                    If objCAPIControl.ControlValue = dVal Then
                      hs.CAPIControlHandler(objCAPIControl)
                      Return 0
                    End If
                  Next
                  hs.WriteLog("error", sDevName + ": " + CStr(dVal))
                  Return 1
                End Function
                Private Function TouchParseStr(ByVal parms As Object, ByVal sSep As String, Optional sDef As String = "") As String()
                ' Takes the input parameter, and returns an array of strings.
                ' If called from event, parms is a single string, so does a split on the specified delimiter.
                ' If called from HS Touch, just returns the string array.
                ' Usage: Sub Main(parms As Obect)
                '          Dim p() As String = TouchParseStr(parms, ",") ' p(0) now contains first, p(1) second, etc
                  Dim buff() As String
                  If parms Is Nothing Then parms = ""
                    If parms.ToString() = "" Then parms = sDef
                    parms = Trim(parms.ToString())
                    buff = parms.Split(sSep)
                  Else
                    buff = parms
                  End If
                  Return buff
                End Function
                Sub Main (parms As Object)
                  SetVirtualVal("DeviceName", CDbl(p(0)), True) ' Convert string to Double
                End Sub
                Hope this helps.
