Random wav file
    Random wav file
    HELP!
    I'd like a script to play a random .wav file from a specified directory. How can this be done?
    Regards, Bob
    Here's a script that plays a random mp3 or wma - you can modify as needed for .wav files - it's terribly inefficient with a large number of files:
    option explicit
    dim fs, root, myFiles(3000), ndx, randomNdx
    set fs = createObject("scripting.filesystemobject")
    set root = fs.getFolder("e:\My Music")
    'load all files into array
    getMusicFiles fs, root
    randomNdx = GetRandomNumber(1,ndx)
    hs.writeLog "randomMusic","found " & ndx & " songs. playing:" & myFiles(randomNdx)
    hs.launch myFiles(randomNdx)
    set fs = nothing
    Function GetRandomNumber(lowerbound,upperbound)
    Randomize
    GetRandomNumber = Int((upperbound - lowerbound + 1) * Rnd + lowerbound)
    End Function
    sub getMusicFiles(fs, folder)
    dim s, objFile, colFiles
    if folder.subFolders.count = 0 then 'grab all files in this folder
    Set colFiles = folder.Files
    For Each objFile in colFiles
    if(fs.getExtensionName(objFile)<>"mp3" and _
    fs.getExtensionName(objFile)<>"MP3" and _
    fs.getExtensionName(objFile)<>"wma" and _
    fs.getExtensionName(objFile)<>"WMA") then
    else
    ndx=ndx+1
    myFiles(ndx) = fs.getAbsolutePathName(objFile)
    'display fs.getAbsolutePathName(objFile)
    end if
    Next
    exit sub
    end if
    dim subFolder
    for each subFolder in folder.subFolders
    getMusicFiles fs, subFolder
    next
    end sub
    sub display(s)
    response.send s + "<br>"
    end sub
    HS4Pro on a Raspberry Pi4
    54 Z-Wave Nodes / 21 Zigbee Devices / 108 Events / 767 Devices
    Plugins: Z-Wave / Zigbee Plus / EasyTrigger / AK Weather / OMNI
    HSTouch Clients: 1 Android
      Thanks Rob,
      I cut and pasted the script (then edited for location, file type, etc.) but it won't work. Can you see what I may be doing wrong.
      Regards, Bob
        ah - try this one instead - I simplified it greatly.
        Change the path and un-comment the hs.launch()
        try it out and let us know...
        Rob
          Rob,
          Thanks, that did the trick.
          Regards, Bob
            I don't know if anyone is interested, but I took Rob's revised script and revised it further for HS 2.x. I took one of our boys' educational applications on birds and copied the 800 bird sound files (all WAV's) to a dedicated folder. When I call this script, it plays one at random. This revised methodology executes about 4x faster, down to one second for 800 files on a 933MHz machine.
            --David
              sub main()
              	dim fs, root, ndx, randomNdx
              	dim objFile, colFiles, strFileName
              	ndx=0
              	set root = fs.getFolder("C:\Program Files\HomeSeer 2\Sounds\Birds")
              	Set colFiles = root.Files
              	randomNdx = cint(GetRandomNumber(1,cint(colFiles.count)))
              	 if ndx=randomNdx then
              		if lcase(fs.getExtensionName(objFile))="wav" then
              			strFileName = fs.getAbsolutePathName(objFile)
              		end if
              		exit for
              	 end if
              	  ndx=ndx+1
              	Next
              	hs.writeLog "RandomBirdSound","Found " & ndx & " files. Playing:" & strFileName
              		hs.mediafilename = strFileName
              		hs.mediaplay
              end sub
              	Randomize
              End Function
              How often do you play these bird sounds?
                Lol!
                  Umm, well, I just got the script running. Heh, heh. I don't really have anything set up yet. My thoughts were to have some random 'environmental' sounds going off now and then (random intervals) to bring the outdoors, in. I have no idea what the wife is going to think of this idea, nor how long it will last. Maybe I'll only run it on the weekends to preserve my life. If we lived in DC, I'd have to substitute the bird environmental sounds for gunshots and sirens.
                  --David
                    David,
                    How are you going to setup up a random event? This actually may not be such a bad idea.
                      Greg,
                      Well, I haven't really thought this through, but my first thought is to set up an event to run at intervals, say every 3 or 7 minutes, and when run, have a weighted determination of whether that particular time will be one in which a random environmental sound is played. I'm not sure if I can programmatically change the interval at which recurring events are fired, but I might periodically change that setting, if possible.
                      Do you have any ideas on the matter?
                      --David
