I've started converting some of my scripts and asp's to .NET but having problems with using the cpuxa object (using the HS Ocelot plugin).
This is the test code:
The error is: 03/04/2006 18:26:43 - Error - Scipt compile error: 'Scheduler.cpuxa' is not accessible in this context because it is 'Private'.on line 15
Do I have to declare the cpuxa object and if so how?
PHP Code:
Sub main (ByVal param As Object)
cpuxa.Setpoint (2,1,1)
end sub
