UPDATE -- I overlooked that I needed to use a hs.CreateVar before the SaveVar. The funny thing is this code is exactly the same as it was running in 2.0.41, but for some reason I never got an error about it. Thanks to HS support for their fast response to my ticket.
Just wanted to give everyone a heads up on a ticket I just opened. After upgrading to 2.1.100, some of my scripts broke. Specifically when using hs.SaveVar and hs.GetVar functions. Here is a copy of the ticket I submitted:
I have scripts which use the hs.SaveVar / hs.GetVar functions. After upgrading to 2.1.100 (from 2.0.41 I think), these functions do not operate as intended. Specificially, they break when using hs.SaveVar to point to an object reference.
Here is an example.
Using the following script:
I get the following in the hs.log:
However, when using hs.SaveVar to place this array in a HomeSeer variable with the following test script:
I get the following error in the HS log:
This same script worked perfectly in previous HS 2.x versions.
Here is an example.
PHP Code:
dim mediaAOLRadioStationNames as New ArrayList()
mediaAOLRadioStationNames.Add("XM The Blend")
mediaAOLRadioStationNames.Add("AOL Pop Remixes")
mediaAOLRadioStationNames.Add("XM BPM")
mediaAOLRadioStationNames.Add("XM Chill")
dim i
for i = 0 to mediaAOLRadioStationNames.count - 1
hs.writelog("test", mediaAOLRadioStationNames(i))
next
6/30/2006 10:01:44 AM test XM The Blend
6/30/2006 10:01:44 AM test AOL Pop Remixes
6/30/2006 10:01:44 AM test XM BPM
6/30/2006 10:01:44 AM test XM Chill
PHP Code:
hs.DeleteVar("mediaAOLRadioStationNames")
hs.SaveVar("mediaAOLRadioStationNames", mediaAOLRadioStationNames)
dim testVar
testVar = hs.GetVar("mediaAOLRadioStationNames")
dim i
for i = 0 to testVar.count - 1
hs.writelog("test", testVar(i))
next
Scripting runtime error: System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.MissingMemberException: Public member 'count' on type 'String' not found. at Microsoft.VisualBasic.CompilerServices.Symbols.Container.Get Members(String& MemberName, Boolean ReportErrors) at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGe t(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack) at scriptcode17.scriptcode17.test(Object dummy) --- End of inner exception stack trace --- at System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) at System.Reflection.MethodBase.Invoke(Object obj, Object[] parameters) at Scheduler.VsaScriptHost.Invoke(String ModuleName, String MethodName, Object[] Arguments)
