Pass Parameters to VB Script
  • #16
    I tried the split function after passing the single variable. It failed. There was no information in the string.
    the parameters in the event were ("Main","Temp Out,5")
    per the example specified.
    • #17
      Try replacing the comma separator with a |
      -Rupp
      • #18
        OK. Not a VB genius here, that's a given. But I usually get by reading and copying examples. I read and read and read this post again, and still getting no love passing multiple parameters to a VB.net script.
        Here are the parameters: ("Main","tester1,tester2,tester3")
        Here is the code:
        Sub Main(ByVal parm as Object)
        Dim parms() As String
        dim st1 as String
        dim st2 as String
        dim st3 as String
        parms = Split(parm.ToString,",")
        st1 = parms(1)
        st2 = parms(2)
        st3 = parms(3)
        'If UBound(parm) > 2 then
        '      st1 = parm(1)
        '      st2 = parm(2)
        '      st3 = parm(3)
        'End If
        hs.WriteLog("Test Script", st1)
        hs.WriteLog("Test Script", st2)
        hs.WriteLog("Test Script", st3)
        End Sub
        I tried both the Split and Ubound methods, with and without ByVal parm and ByVal parm().
        How do I make this work?
        -BD
        • #19
          Try testing it one step at a time by writing some stuff into the log
          hs.writelog("", parm.ToString) - does the log entry look like the parameter?
          hs.writelog("", UBound(parms)) - after you have split it of course, what is written in the log?
          Do you get any errors in the log?
          My Plugins:
          Yeelight 3P | Nanoleaf 3P
          • #20
            st1 = parms(1)
            st2 = parms(2)
            st3 = parms(3)
            You got it except for one simple mistake! In .NET, most everything is zero based (as it should be). When you created the array of 3 objects with the split command, they are in parms 0, 1, and 2 - not 1, 2, 3.
            When troubleshooting in the future, surround big chunks of code with Try/Catch until you see where it is failing, then break that section into smaller chunks until you find the problem. Here is an example of how you could have found this:
            Try
            st1 = parms(1)
            st2 = parms(2)
            st3 = parms(3)
            Catch Ex As Exception
            hs.WriteLog("MyScript Error","Script exception in section 1 is:" & Ex.Message)
            End Try
            It would have shown an "out of bounds" exception as soon as it hit parms(3).
            Hope this helps.
            Rick Tinker (a.k.a. "Tink")
            • #21
              Thought I replied to this earlier...
              Thank you so much for the correction... that resolved it! Also, thanks for the coding tip!
              -BD
              • #22
                Thread necro...but this helped me
                For Each parm_string As String in parms
                  hs.WriteLog("Test Script", "Method A: " + parm_string)
                Next
                For index As Integer = 0 To parms.Length -1
                  hs.WriteLog("Test Script", "Method B: " + parms(index))
                Next
                End Sub
