Is it possible through the hs.NewTimeEvent script command to modify/set the "Do Not Log This Event" checkbox on the event name screen?
I have several delayed events created routinely.. (with delete after run) via scripts.. and I don't really need to see the events run in the log ..
But i can't see how to set this property when creating the event.
Example of how i create the events:
Thank you
index = hs.NewTimeEvent(DelayedEvStr, OffTime, Offdate, True, True, True, True, True, True, True, DevCode & ":" & DAction, True, "") hs.EnableEvent(DelayedEvStr)
