Look for ideas on what to look at to track down this problem.
If I run hs.ExecX10(theDevice, "On") all is well and works.
If I run hs.ExecX10(theDevice, "On", 0, 0, True) the device turns on but HS never shows it as ON untill I send any other device changing command to any device. There are no errors in the log and the log shows the script executed.
I have a CM11a as a x10 interface. Since the TRUE sais do not return untill command sent on powerline and it returns imidiatly it HS apears to know it sent the comand but does not update the device status.
Any ideas on how I can track this down?
