Learn to create script:
  • #31
    Originally posted by ArbWare View Post
    Yes, I use Tenscripting to create and debug...
    Then i copy/paste the working code into a notepad doc.. which i can then put in the script directory....
    Although... i am not sure why i don't share my /Script Directory... i'm not concerned about security behind my router/fire wall.... (maybe i'm naive?)
    I'll have to take a look at that..
    Why not use the tenScripting export file to export your scripts to a temporary directory and then just copy the file from the temporary directory to your script folder. Might be easier than copy and paste, etc. Easiest is to just export to the script folder.
    tenholde
    • #32
      LOL....
      Because.... I didn't know that was possible?
      That will teach me to to read release notes... or go exploring through menus every once in a while... I don't think that the Export was in the original Tenscripting... and i never read the release notes... even though i did update recently..
      Thanks for the great tool.. and like i said.. i should open my eyes more..
      Andrew B.
      • #33
        I get the error on the dateTimeobject. Why?
        Sub Main()
        If DateTime.Now.Hours > 13 Then
        hs.execx10 "Q1","off",0
        end if
        End Sub
        • #34
          Sub Main()
          end if
          End Sub
          It should be DateTime.Now.Hour (singular)
          If you were entering the statement in VS using tenScripting, intellisense should have made that obvious while you were entering the statement.
          tenholde
          tenholde
          • #35
            You are mixing VBScript & VB.NET with the syntax used.
            If DateTime.Now.Hour > 13 Then
            hs.execx10 ("Q1","off",0)
            end if
            End Sub
            This will run only when the script name has a .vb extension (not .txt)
            If you want to do this in VBScript, it would become:
            Sub Main()
            If Hour(Time) > 13 Then
            end if
            End Sub
            This would only run when the script name has a .txt extension
            Jon
            • #36
              Wow, old thread comming up.
              You need to create the "hs" object yourself. Just add this line on the top of your file, but after any Class or Module statement:
              Public hs As HomeSeerAPI.IHSApplication
              Then reference the hs object all you want.
              EDIT: Hmmm! The post I'm replying to is gone? What gives?
              • #37
                HI Mokus - I was going to try to make my message more clear - but you answered the question immediately - Thank you!
                My original post is below:
                Hi Mokus – I have a very basic question. I use tenscripting for script creation and it is an incredibly helpful tool (thank you again tenholder!). However, I wanted to see if I could setup visual studio for HomeSeer VB.NET scripting independent of tenscripting (just for my knowledge and only to take advantage of IntelliSense to help with syntax). I have created a new VB.NET project and I have added references to HSPI.dll, scheduler.dll and HomeSeerAPI (via solution explorer -> My Project -> references). However I am not able to get Intellisense to recognize homeseer functions like hs.DeviceString(). Not sure what I am doing wrong. If you have this documented already (even if it is in Norwegian :-) ) please point me to it (and I will translate with google) – Thank you!
                • #38
                  Mokus - Thank you - this is exactly what i needed. Thank you again!
                  • #39
                    You're welcome!
