Here is some script code to download the memory of an Accu-Chek blood glucose meter that is used by diabetics. It's an example of how to send simple serial commands to a device and read and parse the results. Right now it just takes the readings and writes them to the HS log. I haven't decided how I'm going to use the data in HS yet but I'm thinking about putting it into some type of a file or database so it can be graphed. You need a serial IR data cable from Roche Diagnostics which can be found here:
https://www.accu-chek.com/us/estore....4%26csr%3Dnull
This cable is the same as the Tekram IR-210B IrDA cable but it's only $15 instead of the $29.95 Tekram wants for it.
This code should also work with any IrDA compliant port that supports the IRCOMM protocol.
Tested with an Accu-Chek Compact Plus meter.
' ============================================================================= ' ' Script to Download readings from an Accu-Chek Blood Glucose Meter ' ' Tested with the Roche Diagnostics Serial IR cable which is the same as the ' Tekram IR Mate IR-210B adapter but it should work with just about any IrDA ' compliant device that supports IRCOMM protocol. ' ' Rev 2010xxxx ' ' For best display, use a monospaced font (Courier) with tabs = 4 spaces. ' ' ============================================================================= ' ' Change History ' ' 2010xxxx KLM - Initial Release ' ============================================================================= ' []------------------------------------------------------------[] ' | This code was developed, tested, and debugged using: | ' | | ' | The "tenScripting" HomeSeer Script Development Environment | ' | | ' | If you find this script useful please consider making a | ' | donation here: | ' | | ' | http://www.tenholder.net/tenWare2/CharityWare.aspx | ' []------------------------------------------------------------[] ' This name will appear in the log next to each event log message. Const sC_scriptName = "AccuChek" ' ============================================================================ ' ' HomeSeer Log Output ' ' Actual errors are always logged to the HomeSeer log ' ' For problems, the following constant, scTraceLevel, can be set as follows: ' ' 0 = No trace output ' 1 = Minimal tracing (main methods) ' 2 = Additional method tracing and other activity ' 3 = All methods traced, variable tracing plus additional diagnostic output ' 4 = Very low level tracing (lots and lots of output) ' Const scTraceLevel = 3 ' COM port number for IrDA device Const port = 8 ' ' Definitions for data record ' Dim Reading, rHour, rMinute, rDay, rMonth, rYear, rValid As String ' ' Public Sub Main(ByVal parm As Object) Dim err As String Dim data As String Dim count As Integer Dim num_of_readings As String Dim reading_b1 As String Dim reading_b2 As String Dim reading_b3 As String ' Open COM port in raw mode err = hs.OpenComPort(port, "9600,N,8,1", 0, "", "") If err <> "" Then LogIt("Unable to Open COM" & CStr(port)) Exit Sub Else LogIt("COM" & CStr(port) & " Successfully Opened") End If ' The following commands are just copied from the ' Perl script I found on the internet. ' ' I don't know what they do but things seem to break ' if you don't follow this command sequence. ' hs.SendToComPort(port, Chr(1)) hs.WaitSecs(0.1) hs.SendToComPort(port, Chr(13)) hs.WaitSecs(0.2) TraceIt(4, "0x01 Count=" & hs.GetComPortCount(port)) data = hs.GetComPortData(port) hs.SendToComPort(port, Chr(11)) hs.WaitSecs(0.1) hs.SendToComPort(port, Chr(13)) hs.WaitSecs(0.2) TraceIt(4, "0x0B Count=" & hs.GetComPortCount(port)) data = hs.GetComPortData(port) hs.SendToComPort(port, "C") hs.WaitSecs(0.1) hs.SendToComPort(port, "4") hs.WaitSecs(0.1) hs.SendToComPort(port, Chr(13)) hs.WaitSecs(0.2) TraceIt(4, "C4 Count=" & hs.GetComPortCount(port)) data = hs.GetComPortData(port) hs.SendToComPort(port, "C") hs.WaitSecs(0.1) hs.SendToComPort(port, " ") hs.WaitSecs(0.1) hs.SendToComPort(port, "3") hs.WaitSecs(0.1) hs.SendToComPort(port, Chr(13)) hs.WaitSecs(0.2) TraceIt(4, "C 3 Count=" & hs.GetComPortCount(port)) data = hs.GetComPortData(port) hs.SendToComPort(port, "S") hs.WaitSecs(0.1) hs.SendToComPort(port, " ") hs.WaitSecs(0.1) hs.SendToComPort(port, "1") hs.WaitSecs(0.1) hs.SendToComPort(port, Chr(13)) hs.WaitSecs(0.2) TraceIt(4, "S 1 Count=" & hs.GetComPortCount(port)) data = hs.GetComPortData(port) hs.SendToComPort(port, "S") hs.WaitSecs(0.1) hs.SendToComPort(port, " ") hs.WaitSecs(0.1) hs.SendToComPort(port, "2") hs.WaitSecs(0.1) hs.SendToComPort(port, Chr(13)) hs.WaitSecs(0.2) TraceIt(4, "S 2 Count=" & hs.GetComPortCount(port)) data = hs.GetComPortData(port) ' This command returns the number of readings stored in the meter. ' hs.SendToComPort(port, "`") hs.WaitSecs(0.1) hs.SendToComPort(port, Chr(13)) hs.WaitSecs(0.2) TraceIt(4, Chr(96) & " Count=" & hs.GetComPortCount(port)) data = hs.GetComPortData(port) If Len(data) <> 13 Then LogIt("Problem getting # of readings. Byte count not equal to 13(" & CStr(Len(data)) & ")") hs.CloseComPort(port) Exit Sub Else num_of_readings = Mid(data, 7, 3) reading_b1 = Mid(num_of_readings, 1, 1) reading_b2 = Mid(num_of_readings, 2, 1) reading_b3 = Mid(num_of_readings, 3, 1) TraceIt(3, "Number of readings=" & reading_b1 & reading_b2 & reading_b3) End If hs.SendToComPort(port, "S") hs.WaitSecs(0.1) hs.SendToComPort(port, " ") hs.WaitSecs(0.1) hs.SendToComPort(port, "3") hs.WaitSecs(0.1) hs.SendToComPort(port, Chr(13)) hs.WaitSecs(0.2) TraceIt(4, "S 3 Count=" & hs.GetComPortCount(port)) data = hs.GetComPortData(port) ' Now request the first reading using the number of readings ' from the previous command. ' ' The most recent reading is returned first. ' hs.SendToComPort(port, "a") hs.WaitSecs(0.1) hs.SendToComPort(port, " ") hs.WaitSecs(0.1) hs.SendToComPort(port, "1") hs.WaitSecs(0.1) hs.SendToComPort(port, " ") hs.WaitSecs(0.1) hs.SendToComPort(port, reading_b1) hs.WaitSecs(0.1) hs.SendToComPort(port, reading_b2) hs.WaitSecs(0.1) hs.SendToComPort(port, reading_b3) hs.WaitSecs(0.1) hs.SendToComPort(port, Chr(13)) hs.WaitSecs(0.3) TraceIt(3, "a 1 Count=" & hs.GetComPortCount(port)) data = hs.GetComPortData(port) Reading = Mid(data, 13, 3) rHour = Mid(data, 16, 2) rMinute = Mid(data, 18, 2) rDay = Mid(data, 20, 2) rMonth = Mid(data, 22, 2) rYear = Mid(data, 24, 2) ' This field indicates the difference between a valid ' reading, a control solution test reading, and an ' invalid reading. ' ' 0 = valid ' 2 = control ' 8 = invalid rValid = Mid(data, 26, 1) ' For now just write the reading to the HS logfile. ' LogIt("1:" & ":20" & rYear & ":" & rMonth & ":" & rDay & ":" & _ rHour & ":" & rMinute & ":" & Reading & ":" & rValid) ' Now go get the rest of the readings ' If (IsNumeric(num_of_readings)) Then For count = 2 To CInt(num_of_readings) ' This appears to be a "Next" command the requests the ' next reading which is actually the previous reading since ' the readings are read out in reverse order. ' hs.SendToComPort(port, Chr(6)) hs.WaitSecs(0.3) data = hs.GetComPortData(port) Reading = Mid(data, 5, 3) rHour = Mid(data, 8, 2) rMinute = Mid(data, 10, 2) rDay = Mid(data, 12, 2) rMonth = Mid(data, 14, 2) rYear = Mid(data, 16, 2) ' This field indicates the difference between a valid ' reading, a control solution test reading, and an ' invalid reading. ' ' 0 = valid ' 2 = control ' 8 = invalid rValid = Mid(data, 18, 1) ' For now just write the reading to the HS logfile. ' LogIt(count & ":20" & rYear & ":" & rMonth & ":" & rDay & ":" & _ rHour & ":" & rMinute & ":" & Reading & ":" & rValid) Next End If ' Tell the meter we're done transfering data so it can go to sleep. ' hs.SendToComPort(port, Chr(29)) hs.WaitSecs(0.1) hs.SendToComPort(port, Chr(13)) hs.WaitSecs(0.3) data = hs.GetComPortData(port) hs.CloseComPort(port) End Sub ' ============================================================================ ' L o g g i n g a n d T r a c i n g M e t h o d s ' ============================================================================ ' ============================================================================ ' ' LogIt ' ' Unconditionally log a message to the HomeSeer log ' ' ============================================================================ Private Sub LogIt(ByVal message As String) hs.WriteLog(sC_scriptName, message) End Sub ' ============================================================================ ' ' TraceIt ' ' Output a trace message to the HomeSeer log ' ' ============================================================================ Private Sub TraceIt(ByVal level As Integer, ByVal message As String) 'hs.WriteLog("DEBUG", "Got to TraceIt.1") If (level <= scTraceLevel) Then 'hs.WriteLog("DEBUG", "Got to TraceIt.2") hs.WriteLog(sC_scriptName, "(" & CStr(level) & ") " & message) End If End Sub
