I am puzzled. In a script I try to set a zwave light dimmer on by calling
SetDeviceStatus() that did not work. Then I tried to change the dim in stead with SetDeviceValue(). No luck.
At this point I realized that HS did in fact change the dim value of the device, as the new dim value was reported in the web UI. However, the device did not receive any commands over zwave to change the dim level.
When I turn the device on/off or change dim via the web interface the commands work perfecly.
What am I missing here? This should be homeseer at its most basic level.
