RunScriptEx?
    RunScriptEx?
    I have never used the new RunScript() or RunScriptEx(), but decided to try it out instead of RunEx(). I did a search of the board, and can only find some limited discussion, but nothing about HOW. I looked at the HS On-line help files, and it appears to still be the older version (which I have downloaded via the updater), and doesn't have those functions.
    As best I can tell, these have been around since Feb/Mar-2010. Is there a prototype / help page somewhere?
    Steve
    My local homeseer has both in the help file. Look at {your hs ip}/webhelp/homeseer.htm and look at "Scripting Functions" at the Scripts section.
    James
    Running HS 3 on Win10 .
      Ok James. Fess up! Where did you get this help file?!
      Mine (dated Nov 10, 2009) is the same one as on the Homeseer site, and matches the updater. In my "Scripting Functions", under "For Scripts" I have Run, RunEx, IsScriptRunning, ScriptsRunning, GetScriptPath, WaitEvents, and WaitSecs. *NO* RunScript or RunScriptEx.
      Are you saying there is a newer help file? Why isn't the Homeseer support page pointing to it?
      I think maybe you are "special" and get treated nicer than the rest of us.
      Steve
        Sorry. Instead of "special" maybe I am a different kind of "special". I have the same things in my help as you do. I think I glossed over your "Script" part of the hs.RunScript.
        I should have known you wouldn't be a question that was that simple to answer.
        James
          Ha! I'm not sure that is meant to be a compliment, but I think I'll take it that way!
          Actually, I was hoping you were "special" in the way I meant.
          Anyway, now I'm back to where I started. A search of "RunScriptEx" on the board finds a few where Rick is encouraging people to use it, but I have no idea what the arguments are. I'll hope someone else has some ideas / experience with the new two new methods.
          Steve
            I personally would not use it yet for a public script - not everyone has updated to 2.4
            Jon
              Oh, I completely agree Jon. I was mostly wanting to mess with it on some of my self-inflicted scripts.
              Steve
                I converted my scripts a while back. As I recall, the arguments are the same as before. hs.run("scriptname") --> hs.runscript("scriptname")
                  Wadenut,
                  I think you are mostly right, but I know the new methods must have some new arguments, hence the long argument over overloading vs. new signatures for the routines. I *THINK* the new methods had some sort of optional paramter that the old ones did not. It seems like it was something to do with script actions, but I can't remember.
                  Steve
                    Steve,
                    Look at this post - should help you: http://board.homeseer.com/showpost.p...98&postcount=1
                    Jon
                      Jon,
                      That's exactly what I was looking for! I don't know how I missed that when I was going through the search results, but I did. Thanks!
                      Steve
