Guys..
I'm trying to write a small script that will play an audio CD on my HS PC, I'm told the WMP plugin does not support the playing of them so it looks like i'm going to have to write a script for it.
I've looked around the net and found a few scripts however I can't get them to run on the HS PC. Most involve the MCI interface which I believe is from the VB6 days...
Here is the code for a standalone Vb.net app which works fine on the PC;
I've written a script in HS which is this;
Curiously the current track reports correctly (if I have a CD playing in another application), but I can't get it to play/stop/pause or report the current track number (reports 0)
Anyone any ideas? Or other ideas for different code?
Thanks...
Public Class Form1
Private Declare Function mciSendString Lib "winmm.dll" Alias "mciSendStringA" (ByVal lpstrCommand As String, ByVal lpstrReturnString As String, ByVal uReturnLength As Integer, ByVal hwndCallback As Integer) As Integer
Dim cdDrive As String = "F:\" '<- This is your CD Drive
Dim retVal As Integer
Dim buf As String = Space(128)
Dim buf2 As String = Space(128)
Dim trackCount As Integer
Dim currentTrack As Integer
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
cdDrive = Chr(34) & cdDrive & Chr(34) 'Puts "" Areound the CD Drive "D:\"
retVal = mciSendString("open " & cdDrive & " type cdaudio alias cd wait shareable", vbNullString, 0, 0)
retVal = mciSendString("set cd time format tmsf", vbNullString, 0, 0) 'This will set it so the tracks are recognized as 1 2 3 4...
retVal = mciSendString("status cd number of tracks", buf, 128, 0) 'Get Num. Of Tracks
retVal = mciSendString("status cd current track", buf2, 128, 0) 'Get Current Track
trackCount = CInt(Val(buf)) 'This Will Get the Number Of Tracks (Convert it Into 1 2 3 4...)
currentTrack = CInt(Val(buf2)) 'This Will get the Current Track (Convert it Into 1 2 3 4...)
Label1.Text = currentTrack & "/" & trackCount
NumericUpDown1.Maximum = trackCount + 1
End Sub
Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
retVal = mciSendString("status cd current track", buf2, 128, 0) 'This will get the current Track
currentTrack = CInt(Val(buf2)) 'Converts it into 1 2 3 4...
NumericUpDown1.Value = currentTrack
End Sub
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
retVal = mciSendString("play cd", vbNullString, 0, 0) 'Plays the CD
End Sub
End Class
End Sub
End Sub
End Sub
End Class
Sub Main(ByVal Data As Object)
retval = mciSendString("stop cd wait", 0, 0, 0)
retVal = mciSendString("status cd number of tracks wait", buf, 128, 0) 'Get Num. Of Tracks
hs.writelog("TestCD", currentTrack & "/" & trackCount)
'retVal = mciSendString("play cd", vbNullString, 0, 0) 'Plays the CD
End Sub
End Sub
Thanks...
