I've got a Hometroller on order, and I've got a script that _almost_ does what I want. What I want is to slave a set of dimmers to a set of controller (i.e with two lamps in the room, use the wall switch to control both when the switch doesn't support it natively).
Yet I feel that a plugin could do this better, offer a configuration screen instead of hard coded constants, etc.
If I go through the bother of learning .net, can I write an assembly that will work both with HSPro on Windows7 and on HomeTroller (on an Atom processor)?
Suggestions welcome.
