Hi, all,
I've this http://pastebin.com/V3EE3HTQ code as a result / It seems to be a JSON feed,
the aim is to get (for example) just the ingredient list and the picture of this product (the product can be everything as book, food or anything)
So,
1. Do you know if there is a way to work with this code so easily than we can do with rss feeds in Hstouch designer ?
I searched over the net a way to do it, the only thing I found is http://json.codeplex.com/releases/view/74287 but :
2.1) I need to import (at least?) the Dll, so I entered
in the settings.ini but I just do know if it does something or not ???
2.2) I tried out to import it directly on a script using
or
before the sub but I'm getting few errors like End of instructions expected, or XmlDocument type not specified
the final aim is to be able to do something like zebzeb http://www.youtube.com/watch?v=HAWDOq8d4Nw at 1:25
Can you help me ?
thanks
So,
ScriptingReferences=Newtonsoft.Json.xml;Newtonsoft.Json.dll;Newtonsoft.Json.pdb
inports Newtonsoft.Json.dll
Public Shared Function DeserializeXmlNode ( _ value As String _ ) As XmlDocument
Can you help me ?
thanks
