Retrieve device NAME via script
  • Retrieve device NAME via script
    Hello,
    I have a couple of devices who's names change fairly frequently. In HSTouch I'd like to retrieve their names via script so that I don't have to update HSTouch everytime I change the device names. I can't seem to find a script method to retrieve name but figure there's got to be one. Anyone have any ideas?
    Ben
    Originally posted by bwstein View Post
    Hello,
    Ben
    This might sound crazy, but to me, the solution is to create virtual devices with names that never change. Anytime the name-changing devices status/value updates, an event is triggered to copy status to the corresponding virtual devices. In this way, you can use the device code in the event trigger instead of a device reference (like HSTouch uses in the deployed project xml files) or device name like they appear in the HSTouch designer.
    huggy_d1
    Automating made easy
      I am a bit confused here - HSTouch if you have status tracked these elements then no matter what you change their names to then it should not matter as the tracking (AFAIK) is to the device reference, not the name/code.
      Are you talking about labels that hold just the names of the devices? You could if you wanted put a script command in so these always had the latest names but excessive script commands on a page brings its own set of problems. Something like this might work;
      [$SCRIPT=&hs.getdevicebyref(hs.getdeviceref("A1")).name]
      My Plugins:
      Yeelight 3P | Nanoleaf 3P
        Mr. Happy,
        Yep, that's exactly what I wanted to do. I hope this won't slow the page down too much, it's only about four labels on the page that will have dynamic names. I'll give it a try and see if it has too much of an effect on performance.
        Thanks again
        Ben
          Hm. I was hoping to do something like this in a script I was working on. I haven't figured out how to get the syntax to work right yet.
          Was trying something like:
          hs.WriteLog (MessageID, "Time is set to " & UpTime & " (From Device: " & TimeDevice & " - " & GetDeviceByRef(TimeDevice).name & ")")
          I must be doing something that isn't allow by vb because it doesn't work. . .
            There is actually the function hs.devicename (not in the help file) that will do what you expect, but that syntax would have a number of issues - is that part of a script? Are you able to share the wider script?
            My Plugins:
              Nice! Not sure why that isn't in the help!
              Hm. The script is probably a bit large to post inline. I am basically tweaking the Alarm Clock script from here:
              https://forums.homeseer.com/showthread.php?t=157784
              I got it working for HS3, but I was just trying to make the log descriptions easier to understand with names instead of just the device reference.
                if you are just after the device name use something like
                PHP Code:
                        Dim Ref As Integer 1234
                        Dim Name
                As String Nothing
                        Dim dv
                As Scheduler.Classes.DeviceClass
                        dv
                hs.GetDeviceByRef(Ref)
                Name dv.Name(hs
                hs.devicename is ok but it returns the type and location to.
                Greig.
                Scripts =
                Various
                  PHP Code:
                          Dim Name
                  As String Nothing
                          Dim dv
                          dv
                  Name dv.Name(hs
                  Greig.
                  Nice. That is what I was missing. Didn't know what type to use in the Dim statement in order to access the device as an object. Thanks.
