What am I doing wrong ? - Solved!
    Trying to read a sensor value from a file, and my script will not let me create a new device :
    sub main ()
    Dim dv
    Dim oFSO, sFile, oFile, sText, holder, dvRef
    Set oFSO = CreateObject("Scripting.FileSystemObject")
    sFile = "c:/ProgramData/masterbeddroom.txt"
    If oFSO.FileExists(sFile) Then
    If hs.DeviceExistsRef("/10") = "-1" then
    dv = hs.NewDeviceEx("Temperature")
    REM set the other properties
    dv.hc = "/"
    dv.dc = "10"
    dv.location = "Master Bedroom"
    dv.location2 = "Main Floor"
    dv.dev_type_string = "Status Only"
    hs.SaveEventsDevices()
    end if
    Set oFile = oFSO.OpenTextFile(sFile, 1)
    Do While Not oFile.AtEndOfStream
    sText = oFile.ReadLine
    hs.setdevicestring "/10",stext, True
    Loop
    oFile.Close
    I get this error message :
    "Running script, script run or compile error in file: Get Master Bedroom Temp.txt438:Object doesn't support this property or method in line 15 More info: Object doesn't support this property or method
    I tried defining the variable dv as an object at the start of the routine :
    "Dim dv as object"
    and I would get this error message :
    "Error - Running script, script run or compile error in file: Get Master Bedroom Temp.txt1025:Expected end of statement in line 3 More info: Expected end of statement"
    DeviceExistsRef returns a long value not a string.
    Try this
    If hs.DeviceExistsRef("/10") = -1 then
    Also check your log file for any errors.
    Jeff Farmer
    HS 3, HSPhone
      Ok, now the log file has a new error :
      "Running script, script run or compile error in file: Get Master Bedroom Temp.txt438:Object doesn't support this property or method in line 15 More info: Object doesn't support this property or method"
      which refers to the line :
        I got it, everyone...
        I didn't use the "set" prefix prior to defining the new device.
        Thanks all !
          One more question....
          Well, although I can now create the devices needed, unfortunately the "on" & "off" buttons still appear to the right of the status page.....even tho I specifically set the "status only" properties of the device :
          "dv.dev_type_string = "Status Only" "
          Any ideas how I might remove these buttons in the script ?
            The dev_type_string setting just changes what is in the Type column in the web UI, I dont think it does anything else.
            You will need to set the .misc value to &H10 for a status only device, like this;
            dv.hc = "/"
            dv.dc = "10"
            dv.misc = &H10
              Thanks, Happy...I appreciate it.
