I've got a script (vb.net) that creates several events for me, as an easy way to set up my little "system". A couple of the events (via Voice Recognition over my Way2Call phone) erroneously run several instances of my script at the same time. Nothing like hearing "Microsoft Anna" repeating the same command requests over and over...
The only solution I have found is to check the "Wait for script to finish" box under the script action in the event web interface. The problem is, I cannot find a way to set this when I create the event via my scripts.
Is there any way to enable "wait for script to finish" when creating the event action in the script? The only parameter I see documented for the ACTION_SCRIPT type is Parm 1 (the script file name).
--Doug
--Doug
