I've a very starnge problem with a script I use to control my heating. The stragest thing is that this was working perfectly, but stopped working all of a sudden.
Here is a part of my script causing me the problems
start-----------------------
'Get workshop desired temp
workshop_therm = hs.devicestring ("t14")
'get workshop current temp
workshop_current = hs.devicestring ("w5")
hs.WriteLog "workshop_current=",workshop_current
hs.WriteLog "workshop_therm=",workshop_therm
if workshop_current < workshop_therm then
hs.WriteLog "workheat","in event to cold"
'hs.WriteLog "workshop","fancoil on"
boiler = "On"
fancoil = "On"
End if
--------------------end
In the event log I get the following
21/01/2013 15:04:04 - workshop_current= - 4.5
21/01/2013 15:04:04 - workshop_therm= - 21
and it does not enter the event.
If replace the "<" sign for a great ">" sign then the script enters the if loop.
also if If change statement to be "if 4 < workshop_therm then" it also enters the loop.
any ideas whats going on?
boiler = "On"
fancoil = "On"
End if
