iPort and listening for JSON command
  • iPort and listening for JSON command
    I have just bought a iPort Surface Mount to use an iPad with HSTouch. I actually ordered on without buttons n=but was sent one with buttons.
    http://iportproducts.com/surfacemoun...ntbuttonsintro
    The buttons send a JSON message as follows:
    {"deviceid":"SurfaceMount","model":"iPortSM6B","macaddr":"00 80A38A4002",
    "version":"V6","upLme":"21301","evenfme":"21301","events ":[{"label":"key 3","state":"1"}]}
    I have done a bit of script progamming. Can some one get me started as to how to get HS3 to listen, capture and "import" this data into an HS3 script for multiplication.
    This is one of those things that may be a bit painful - when you say it sends data what does it do - does it post to a TCP socket, make a HTTP POST/PUT or some other method?
    My Plugins:
    Yeelight 3P | Nanoleaf 3P
      I'm not sure.
      If you telnet the device every time a button is pressed it transmits the JSON information.
      Does that help narrow it down ?
        That would point to the first thought really, unless there is the ability in the settings to specify a web server to post to. Will depend on the documentation really, I think the only option if it is on a socket is to either write your own plugin (painful) or try drules IP plugin (I've no experience of that myself).
        My Plugins:
          Originally posted by SgtBilko View Post
          I'm not sure.
          It appears that you will need to write a script that will telnet to the device and stay connected performing a loop for each button press. The script will need to convert the received JSON message to a http get/post call in the format expected by HS3'S JSON interface (http://homeseer.com/support/homeseer...nk/default.htm)
            Anyone this is doable enough to order them and hope to do later?
              I just requested their API. I by no means am capable enough of building a plugin, but maybe someone here is!
              Below is the link to where we can request the API:
              https://iportproducts.com/smbuttonsconfig
                Was this ever made into a plug-in or was a solution ever figured out? I would love to use one of these.
