Little help (error) on Kevin's Thermostat script
    If any one can help - I have been getting this error message for some time now (doesn't seem to affect much):
    1/18/2002 6:13:28 PM~!~X10 Received~!~J6 (?) J Preset Dim 8
    1/18/2002 6:13:28 PM~!~Event Trigger~!~X10 Trigger (RCS Receive J)
    1/18/2002 6:13:28 PM~!~X10 Received~!~J15 (?) J Preset Dim 2
    1/18/2002 6:13:29 PM~!~Info~!~ Script Error, File: rcs_tx15b.thm: 0: in line 0
    1/18/2002 6:13:30 PM~!~ThermoStat~!~Indoor Temp 70°/SP:71/M:Heat/F:Auto
    1/18/2002 6:13:30 PM~!~Info~!~ Script Error, File: rcs_tx15b.thm: 0: in line 0
    It always refers to line "0" - any ideas? Here are the first few lines of script I am using:
    SUB Main(Parm)
    DIM I, TS
    TS = hs.GetVar(ThermoStat)
    I = 1
    DO UNTIL I > LEN(TS)
    hs.DisableEvent "ThermoStat Monitor-" & MID(TS, I, 1)
    I = I + 1
    LOOP
    Parm = UCASE(Parm)
    SELECT CASE Parm
    CASE "MONITOR"
    ThermoStat_Monitor
    CASE "UPDATE"
    Thermostat code is "J", using Version 3.0 BETA
    Thanks in advance!
    Patrick
    Patrick, did you disable the event that Rich activates by default when you add a TSTAT. The Event is "RCS Receive J",and is different from the events I create.
    I've been real busy, but I have a slightly updated Beta that disables that event. I have a couple of other updates I want to finish before I release this as live code.
    KlK
    p.s. feel free to e-mail me directly with issue's.
