Correct format of the ExcludeSensors ini setting
    Can someone tell me the correct format of the ExcludeSensors ini entry. I have it as
    <pre class="ip-ubbcode-code-pre">
    ExcludeSensors="MS Front Porch Hawkeye II, MS Deck Hawkeye II"
    </pre>
    but my occupancy sensor still seems to be picking them up. Does each sensor need to be enclosed in quotes? TIA
    -Rupp
    ...One Nation Under GOD, Indivisible, With Liberty And Justice For All.
    -Rupp
    Is this the script version or the plug-in?
    If it's the script version, then I think all MS device names must be suffixed with "&lt;space&gt;MS" instead of prefixed - the comma is the delimeter, tho...
    Rob Mason
    68 Z-Wave Nodes, 175 Events, 359 Devices
      The MS is not the perfix for the device type. I stuck MS in front of all my motion sensors locations as well so they all show up in the status view together. So I'm still confused as to the format?
      -Rupp
      -Rupp
        So you're using the script version?
        If so, according to the docs the comma is the separator.
        There's a function called isExcluded(), or something to that effect, that tests if a particular device is present in that list. You might need to write a quick script to see...
        Rob Mason
          I found it. It was a typo. I had MS Deck HawkEye II and it should have been MS Deck Hawkeye II. That dang cap E. Thanks for the heads up.
          -Rupp
          -Rupp
