Errors in multiple scripts
    I'm running the latest hs beta on a winxp machine as a service. I just did a clean install. Everything worked fine at first. Now with hourly_forcast, weather(3 day forecast) and the startup script, I get basically this same error in the log. It is always 0: in line 0
    11/5/2002 8:17:26 AM~!~Error~!~Script error in file: hourly_forecast.txt: 0: in line 0
    11/5/2002 8:17:26 AM~!~Error~!~Script error in file: spawn.txt: 0: in line 0
    I haven't changed any of these scripts but I can't figure out what the problem is. Thanks for any help.
    Shane
    I cannot be of too much help. There is a similiar discussion at 0 at line 0
    It has been awhile since I received some of these and if I recall the solution was generally some problem with the script file that was sufficiently high level that it would not allow the main procedure to be recognized, hence the only line reference it could provide was 0.
