RCS TX15B Autosend Script (nak_rcs_tx15b) ERRORs
    I have two RCS thermostats (hosuecodes I & J). The script has no problem initializing:
    11/4/2002 8:55:59 AM~!~RCS TX15B Thermostat~!~@ House Code: J Initialized
    11/4/2002 8:55:59 AM~!~RCS TX15B Thermostat~!~@ House Code: I Initialized
    Status reporting is working correctly:
    11/4/2002 12:00:19 AM~!~TX15B Status Report~!~System Started: Temperature is 73
    11/4/2002 12:08:35 AM~!~TX15B Status Report~!~System Stopped after 8 (8) minutes: Temperature is 74
    I run into problems trying to control stat from web:
    11/4/2002 11:54:13 AM~!~Error~!~Script error in file: rcs_tx15b.thm: 13:Type mismatch: CINT in line 275
    11/4/2002 11:54:26 AM~!~Error~!~Script error in file: rcs_tx15b.thm: 13:Type mismatch: CINT in line 275
    11/4/2002 11:54:36 AM~!~Error~!~Script error in file: rcs_tx15b.thm: 13:Type mismatch: CINT in line 490
    11/4/2002 11:54:36 AM~!~Send X10 from ext interface~!~J3 preset dim dim: 5 extra: 0
    11/4/2002 11:54:54 AM~!~Error~!~Script error in file: rcs_tx15b.thm: 13:Type mismatch: CINT in line 275
    Any ideas?
    Larry
    HS V1.6.21
    Larry
    Looking at your log entries it looks like the "standard" RCS TX15B script is controlling one of the stats. How did you set up your two stat devices?
    Grant
    Win2KSP2
    HS v1.6.24 beta
    HouseLinc (firmware v 4.4) X-10 Interface (v 1.1.16)
    MR26A (v 1.01.0617)
    RCS TX15B 'stat
    HS Phone v 1.0.0.70 beta
    Hi-Phone (firmware 4.51.03) Interface v 1.08.12
      Device Name:Thermostat
      Type: RCS TX15B Therostat
      House I & House J
      This is what I missing:
      specify "nak_rcs_tx15b_main.thm" as the controlling script
      How & or where?
      [This message was edited by LPC on Tuesday, 05 November 2002 at 02:33 PM.]
      Larry
        Select the "Device Types" tab. In the List Box (Titled: "Select a type then select attributes:"), select "RCS TX15B Thermostat".
        Now, select "nak_rcs_tx15b_main.thm" in the drop down box titled: "Thermostat --> Script:"
        OK to exit and save. Now the controlling script will be my script, not the default one included with HS.
        Grant
        Win2KSP2
        HS v1.6.24 beta
        MR26A (v 1.01.0617)
        RCS TX15B 'stat
          I am up and running. Thanks for the script.
          Are you or any other script writers working on a script that graphs the run times?
          Larry
