Please use this thread for comments, questions, etc. for the script posted here: https://forums.homeseer.com/showthread.php?t=187187.
Script to list events that have script actions - Discussion Thread
Al,
Again, seriously, why don't you just setup my system for me? I was just starting to run into similar as I tested out various parts of my updateEvent master script.
Now, I can just run your good stuff and be happy - yet again!
--DanTasker, to a person who does Homeautomation...is like walking up to a Crack Treatment facility with a truck full of 3lb bags of crack. Then for each person that walks in and out smack them in the face with an open bag.
--Dan
No problem, just sent it over along with some (a lot of) beer and I'll have it ready in a few months
Cheers
AlHS 3.0.0.548: 1990 Devices 1172 Events
One thing that I have noticed on my Windows system is that most scripts are referenced using the path with this capitalization:
Code:C:/Program Files (x86)/HomeSeer HS3/scripts/
Code:C:/program files (x86)/homeseer hs3/scripts/
To catch all scripts/events, you would need to run the script twice modifying the ScriptsPath variable. I'll see if I can update the script to take both scenarios into account automatically. Would be interesting to know what other people are seeing for paths to their scripts in events.
Cheers
Hi Al;
Can't seem to get this script to run on my system. I changed the path for the scripts files to reflect my directory, added the reference for the needed dll in the system.ini file but I'm getting this error in my log.
PHP Code:Syntax error.
Feb-07 11:59:48 AM Error Compiling script EventswithScripts.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
Any suggestions?
ThanksDon
Sure.
PHP Code:ScriptingReferences=DDay.iCal;DDay.iCal.dll,DDay.Collections;DDay.Collections.dll,antlr.runtime;antlr.runtime.dll,System.Data.SQLite;C:\HomeSeer HS3\Bin\System.Data.SQLite.dll
Cheers
First, thanks for all the help.
I realized that I had renamed the data file to LostHorse.hsd. So I blew it there. I redid the statement to reflect the correct name of my file to
PHP Code:Dim HS3DataFile As String = "LostHorse.hsd"
Originally posted by sparkman View PostHi Don, all looks good there. The other Imports should not require mods to the ScriptingReferences, so not sure what is going on. Can you set the Debug variable to True in the Main Sub as well as the one in the EventsWithScripts function? It likely may not tell us more if it fails to compile all together. If that doesn't tell us anything, I'll create a simpler test script to see if we can pinpoint the issue. Also, can you confirm the name of your HS data file?
Cheers
AlDon
Well; this is embarrassing. I had put a comment in while trying to troubleshoot the script and, well nevermind. It works now. I think putting the wrong data file name broke it and when I was trying to fix it, I really broke it, so I didn't notice that it was working.... Very red faced here.
That would be great if you could do that.
AlDon
Originally posted by donstephens View PostWell; this is embarrassing. I had put a comment in while trying to troubleshoot the script and, well nevermind. It works now. I think putting the wrong data file name broke it and when I was trying to fix it, I really broke it, so I didn't notice that it was working.... Very red faced here.
ThanksGlad it's now working for you.
Cheers
This is super great Al. Though, I did try it and edited into the aspx file my hsd filename and path to SQLite but get the following error.
Line 47:
Line 48: 'Declare the main SQLite data access objects
Line 49: Dim cnn As SQLiteConnection = Nothing
Line 50: Dim comm As SQLiteCommand = Nothing
Line 51: Dim rdr As SQLiteDataReader = Nothing
Source File: C:\Program Files\HomeSeer HS3\html\scriptevents.aspx Line: 49
I've added the following reference to settings.ini
System.Data.SQLite;C:\Program Files\HomeSeer HS3\Bin\System.Data.SQLite.dll
RobertHS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
