Problem with XLgraph
    After the graph is shown in Excel I got the error: Script error in file: XLGraph.vbs: 1004:Unknown runtime error in line 136
    Please advise
    Which version are you running? Version is listed in the comments at the top of the file.
    jim
      I downloaded the XLGraph-v1.52.zip file. So I am using XLGraph.vbs v1.5
      I also use WinXP and Office2000 both Norwegian version. The regional setting of my OS is set to English (Storbritannia)
      I have tried XLGraph on different PC’s (win2000 and Office97) with the same result: error in line 136.
        I think this might be it. What is the default name of the first worksheet when you start Excel? Currently Xlgraph is assuming that it is "sheet1".
        If it is not "sheet1" then you can do a temporary fix by doing a search and replace on "sheet1" and replace it with whatever name your default worksheet has.
        Let me know if that's it. If it is then I'll incorporate a fix in the next update. If it isn't then we'll keep working on it.
        jim
          Thanks a lot. That worked. [img]/infopop/emoticons/icon_smile.gif[/img]
