AT&T Voices Weather Report Discussion
    #31
    Accuweather is still okay for the AT&T Voices Weather script. If you look in the script, I am going to a specific web page within AccuWeather.com and not the "regular" web page. The URL for my current weather is http://www.accuweather.com/uwp/weath.../46322/Current which returns:
    <pre class="ip-ubbcode-code-pre">
    &lt;HDML VERSION=2.0 TTL=0 MARKABLE=TRUE&gt;
    &lt;DISPLAY Name=Current&gt;
    &lt;line&gt; 06:56 am CDT
    &lt;line&gt;Temp: 41 F
    &lt;line&gt;P/SUNNY
    &lt;line&gt;Pres: 30.17
    &lt;line&gt;Hum: 70%
    &lt;line&gt;Wind: N at 12
    &lt;line&gt;AccuWeather, Inc
    &lt;/Display&gt;
    &lt;/HDML&gt;
    </pre>
    which is a very small web page perfect for WAP.
    I "simply" use GetUrl to retrieve this text, store the lines in an array, and then parse it to find the values. Not sure why you would N/A but it would not be from my script it would be from AccuWeather. Don't know how to solve this. I just tried 55303 and it worked fine.
    Jim Doolittle
    [This message was edited by Jim Doolittle on Saturday, 18 May 2002 at 08:28 AM.]
    Jim Doolittle
    My Twitter
    My Hardware & Software
      #32
      I took your url and replaced your zip with mine and the file looks just like the one you posted. So I looked at the hs screen and all is working fine. Now why didn't I go and look at the hs screen first? Thanks for the reply.
        #33
        Jim,
        Very Nice. Just downloaded and installed easily in a snap. Clean and well documented.....very nice job. Thanks!
        Also setup an event that triggers every morning during breakfast time, and reads the weather. This is the ultimate laziness!
        New voices ordered.....
        Win2000 Pro SP2, IE6, 1333Mhz256KRAM, PN576V, MR26a-B10, HS-B42, HSP-B17, VR/TTS-SAPI5
        [This message was edited by DaveB on Sunday, 19 May 2002 at 08:39 AM.]
          #34
          Excellent script Jim...been using it now for a few weeks. Today changed over to just Crystal to speed it up some. I am looking to use both virtual and real devices and I would like to use my weather station info which is basically outside temp/humidity, various inside temp/humidity, outside wind/direction and the rest of the WEB based stuff. Can I do both?
          - Pete
          Auto mator
          HS4 Pro - V4.1.10.0 - Ubuntu 18.04/VB W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.12.x
          HS4 Lite -
            #35
            I have installed the last version of my_weather
            and it still says "less then voice required.
            I have installed the att true voices but cannot seem to get it to work in my_weather.
            Please help
            Joe
            jjsmd@yahoo.com
            jjsmd@yahoo.com
              #36
              I see no problem having multiple sources of weather (or any other type of information) be it hardware (weather station) or software (web data retrievel) as long as the virtual device codes do not coincide.
              Jim Doolittle
              Jim Doolittle
              My Twitter
                #37
                jjmsd,
                I may be wrong but it sounds like AT&T voices are not working properly for you and they are not interpreting the XML (&lt;Voice=""&gt;&lt;/Voice&gt; ) tags.
                Jim Doolittle
                Jim Doolittle
                My Twitter
                  #38
                  I believe ATT True Voices are working. They seem to work when I try to run the Microsfot Speech SDK 5.1. And they also show op on the options in TTS in HS.
                  But it seems this line in the script
                  If who &lt;&gt; "" Then txt ="&lt;Voice Required='Name="+who+"'&gt;" & txt & "&lt;/Voice&gt;"
                  just does not get interpeted correctly. Any one have any suggestions? ( I tried the one with the Line/line to no avail)
                  Joe
                  jjsmd@yahoo.com
                  jjsmd@yahoo.com
                    #39
                    Jim
                    Can you look at the dooguestbook.asp discussion?
                    I am signing in but am unable to get a list of all visitors.
                    Joe
                    jjsmd@yahoo.com
                    jjsmd@yahoo.com
                      #40
                      This script is broken for me. It used to work flawlessly but as of some weeks ago, the script starts, speaks the first phrase "Getting weather, hold on" and stops.
                      In the log I am getting an error saying "Script error in file my_weather.txt: 9 subscript out of range '[number 3]' in line 201.
                      I haven't seen anyone else having this problem, I am running version 1.16 of that script only triggered by voice command.
                      Bernie
