X10 Status is a web page that graphically displays a range of devices showing status
as well as providing a icon to click to change the status. Mouse-over actions display
the homeseer device location and name for the device icon. The icon is a small led
with color of red, yellow, green, light blue, or dark blue to indicate current status of
off, dim, on, unknown, not defined with homeseer, respectively. The overall view of the
grid provides a good glimpse of the overall mapping of defined devices and their current
state.
It is useful as a test page as well as a good view of what devices are defined within
homeseer.
The status is updated periodically using hidden frame technology so only the led's that
change will be updated. The update rate is defined at the top of the file. Likewise the
range of devices to display is selectable. By default the entire homeseer set of house
codes A-Z and device code 1-64 are generated. A display this dense is not appropriate for
a low-powered client such as Audrey.
When an icon is clicked the state is toggle off-on, or off-dim-on if the device is dimable.
If it is in the X10 range then the X10 command will be generated, otherwise status will
be updated directly. Undefined devices will still generate X10 traffic, however since
homeseer is not aware of these devices the status will not be updated.
When the mouse is positioned over an icon the homeseer device name is displayed next to the
cursor and in the status window for IE. If it is not defined, then only the house and
unit codes are shown.
Archive is located in Script library at
Graphical Device Status and Control
state.
homeseer.
