The setup instructions seem a bit skimpy. I put the two .asp files into my HomeSeer HTML directory and then browsed to the ir_setup.asp one, and got a nearly empty page -- header bar, then bottom links, nothing between. Tried in both Opera and IE, same results. Nothing in the log. No error messages.
I've got the "standard includes" (I wish you guys would come up with a real name for them) installed but not much else. If there's more required, I don't know what's needed.
Nucleus Home Automation | System Specs
