Warning: This script will overwrite your existing 'check_vcmd.txt' file if it already exists. So backup or rename this file if you are already doing something with it.
This script will not only give multiple responses to the attention/ignore phrase it will
determine if your computer is in a good mood or bad mood. You will never know if you will be dealing with a pleasant helpful assistant, or an irritated, complaining assitant.If in a bad mood, HS will complain about having to do all those chores and not feeling appreciated.
Setup:
1. Drop these files into Program files/HomeSeer/scripts.
2. Go to View->Options->Voice Recognition. Delete the 'Attention Acknowledge Phrase' and the 'Ignore Acknowledge Phrase'. Keep both Voice Commands.
(Note: you will have to delete these two phrases each time you restart HomeSeer. If those fields are blank HS will insert the default 'Yes sire' and 'goodbye' phrases.I don't know how to get around this. If anybody knows let me know.)
That's all you need if you want HS to only give responses to the attention/ignore phrases,
If you want HS to complain while doing stuff follow these steps.
3. Create an Event called 'Complain' and have it call the 'complain.txt' file.
4. Go to another Event particularly one that you give voice commands to like your "What time is it" event.
5. Go to the Event Properties page. Click on the Run Events tab.
6. Scroll through the Available Events until you find 'Complain' and add it to the Run Order box.
You may find that you are getting more bad moods than good. Go into check_vcmd.txt and change the bad mood phrases to good moods.
You can edit the scripts to tailor the phrases to your own liking. I think I documented enough to show you how to change it. Look at both txt files and look for the phrases to change.
If you want to uninstall The Moody Computer all you have to do is delete 'check_vcmd.txt' file or rename it and restart HomeSeer.
Let me know of any problems.
Danny Norris
Setup:
Danny Norris
