XML Weather Problem
    XML Weather Problem
    When I run this script, I get the following error in my HS log:
    Script Error in file:XML Weather.txt: 70:Permission denied: 'inputbox' in line 71
    Any clues?
    Are you running as an administrator on the machine your getting the error on? Are you running any virus software that also blocks script messages? What OS?
    -Rupp
    ...One Nation Under GOD, Indivisible, With Liberty And Justice For All.
    -Rupp
      Rupp,
      I *think* I'm running as administrator. How do I tell exactly?
      No Virus protection software.
      I'm running Windows XP Home Edition.
        Select the path Start > Control Panel > Administrative Tools > Computer Management
        Then select Local Users and Groups. Double click on Groups. Double click on Administrators. Is your login name mentioned?
        Sunset, You don't have scripts can not display dialogs check in HS general options do you?
        -Rupp
        -Rupp
          <BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Sunset, You don't have scripts can not display dialogs check in HS general options do you?
          <HR></BLOCKQUOTE>
          I did have this option checked...I unchecked it & it ran fine. Thanks, Rupp!
